FASS questions
Old 08-24-2005, 09:28 AM
RowJ's Avatar
Originally posted by AAmeeting
Cobtex the FASS gets rid of the factory filter. It runs a huge fuel line from the Fass directly to the IP. Very cool.
That's the FASS I...Crobtex was speaking about the FASS II.
You had asked about filter changes on the FASS I.
It comes with a 10 micron filter...same a the dodge fuel filters. These are bigger than the dodge filters and should last 50,000 miles comfortably. When they first came out, someone waited till he lost fuel pressure...just to see how long it would go. Believe he changed it at 100,000 miles...but that was a max duration test.
I ran the 5 micron filter (Baldwin) on the approved filter list for 20,000 miles with no clogging.....and no loss of fuel pressure, even at WOT. Changed it out cause I want to cut it open and see how it looks. Have not made time to do that yet...but 20,000 miles seems about right for this tighter filter?
RJ
Old 08-24-2005, 11:44 PM
AAmeeting's Avatar
My mistake. How do you know what filters will work? Like your 5 micron.
Old 08-25-2005, 06:42 AM
RowJ's Avatar
If you mean What Brands...a list comes with the FASS.
If you mean.. will a tighter filteration work...trial & error.
RJ
Old 08-27-2005, 02:30 PM
jwjgt's Avatar
I got the 95gpm w/filter ,run 18 all the time ,ran it to stock filter so water in fuel light will work.
Old 08-29-2005, 10:23 AM
farmer dave's Avatar
jwjgt,
So you are running it through 2 filter systems?
Old 08-29-2005, 10:51 AM
RowJ's Avatar
Originally posted by jwjgt
I got the 95gpm w/filter , ran it to stock filter so water in fuel light will work.
MY H2O in fuel light still works...without the Stock fuel filter canister.
RJ
Old 08-29-2005, 09:00 PM
AAmeeting's Avatar
Did you move the sensor?
Old 08-30-2005, 07:43 AM
RowJ's Avatar
Not sure...a friend helped me with the install, and he is the electrician in our group....so he did the wiring part.
Called him and asked....Sorry, I DO NOT have the sensor hooked up. My light will come on when I wash my FASS...He said I'm probably just grounding out the conection where the sensor was hooked up.
RJ
BCarmicle
13
11-07-2005 04:20 PM
Buckshotmckee
05-23-2005 12:08 AM
2wheelsup
05-17-2005 10:45 PM
Flatty
04-25-2005 12:49 PM
ralphie
04-21-2005 12:51 PM
Quick Reply: FASS questions
