FASS questions
FASS questions
How much pressure and volume should I expect from a FASS? I am going to get one on thursday from Daves Diesel in Muncie IN. I have replaced my carter with the one from summit only to get an erratic fuel pressure reading and only 9psi. Will this Fass Give me 15 psi at all speeds? Is ther anything better than the FASS? I saw a demonstraion at the DHRA show and it took all the bubbles out of the fuel. Any bad things? Thank you all T
I just bought and installed a FASS system on my truck three weeks ago my fuel presure is 18.5 psi idling and at wot i cant get it below 16 psi the truck does seem to run better there was nothing wrong with my lift pump i just do a lot of driving and wanted to up grade my fuel system before the pump did go out and leave me stranded.
Get the FASS 95gpm not the 150gpm. The 95 is more then enough. I see 20-21psi @ idle, 19psi @ cruise and I can pull it down to 15-16psi if I really get on it.
Originally posted by rebal
mine runs at 15psi and stays there at WOT
May drop 1-2 lbs at WOT for a split second..than right back up to 15! 95 gph model is all that's needed on any hp CTD! Our engines only burn 3-6 gph at cruise.
RJ
Be sure to add the larger line and fitting "kit" between the filter and the VP 44. You can rig it with parts from NAPA or order from one of the DTR vendors.
Originally posted by Rodram2002
Hey guys. I'm also looking at the FASS. or FASS II I should say. My goal is 500hp Do I need a 150gph or just the 95 one? Thanks.
RJ
