View Poll Results: Which FASS Pump
1003 - 95 GPH With Big Line filter to injection kit
8.33%
1003 - 95 GPH With
8.33%
1003 - 150 GPH With Big Line filter to injection kit
8.33%
1003 - 150 GPH With Draw straw II 3/8
16.67%
1008 - 95 GPH
8.33%
1008 - 150 GPH
16.67%
Other - Please list in the thread
0
0%
I have no idea but I like to vote anyways
33.33%
Voters: 12. You may not vote on this poll
Which FASS Pump To Get For My Truck
Everydaydiesel,
The Fass w/filters kit completely eliminates your banjos. If you look at your pictures above, the small silver block with the red cap in it, that has a port on the side where you attatch your fuel psi gauge to.
Everydaydiesel, a 1008 with the filter and seperator came into the shop tonight and i'll be installing it on an '02 sometime this week. I'll let you know how it all goes, plus i had a quick look inside the box and noticed a decent size coil of fuel line. I'll keep you posted.
Cheers!
Cheers!
Cheers!
Cheers!
Also where is everyone mounting the FASS? On the frame just behind the cab?
...not completely sure, i was in a bit of a rush to get home and didn't spend much time tearing through the box. I can't see why you'd have to tie into the return line for any reason. But i guess i'll find that out sometime mid-week!
Cheers!
Dan
Cheers!
Dan
Thanks dan,
I just found this and ill post it up, it may help someone in the future
Install manual for FASS
http://www.dieselpp.com/billcook/FAS...l%20Manual.pdf
Bradleysram
19
05-12-2009 08:36 AM
mkeanglorldo56
05-31-2007 07:34 AM
Fishjager
03-23-2007 06:03 PM
tywebb3
06-23-2006 11:30 PM
