Fass Install Question
The question: nothing in the directions address the in-tank pump's fuel level sender. Definitely want the fuel level sender active. The directions I have don't refer to an 02 with the in tank pump so I'm wondering if anyone has some experience - I'd like to know what to expect before I take the tank out and start. As I remember from the Glacier directions there is some splicing to do. And since its already there, I'd like to be able in case of a Fass failure to rehook up the in tank pump.
Then if you ever wanted to use the in-tank pump again, all you would need to do it unplug our harness and plug the in-tank pump back up. Then hook up your stock fuel line and you would be set.
If you have the in-tank pump you have to use the STK-1001 or Draw Straw II
Topper
02-04-2008 01:18 PM
kully560
03-18-2006 07:04 PM
Ramirezh
18
03-12-2006 08:41 PM
Bad Ramer Jamer
12-30-2005 01:37 PM
