fass install
fass install
im going to buy a bigger lift pump right away here. i was thinking a fass cuz i ccan get a good deal on em through work. i checked today and i currently have the in tank lp. wwhat do i need to do with that when installing the fass?
does it have to come out?
Yup, no issues with psi, can hold her wide open to 100mph and fuel pressure stays around 8-10, idle is 15. If the intake pump dies I don't know if the FASS will be able to suck through the stock pump though,
I think vulcan or airdog has some kit to replace the intank pump with a hose/plate or something like that, so that you can run an external pump. or you could drawstraw it
personally dont think its a good idea to leave the old one in there, pumps are pushers not suckers, and if you restrict the suck side.... (again just my opinion)
I though you would need a draw straw or helmann sump. I was told you couldn't draw through the intank LP.and you can only draw thru the canister if you are still using a fuel filter mounted pump.
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
you can get away with it, but i really don't recomend it. If you cheap like me you can buy a 3/8 chunk of hose thats diesel rated, and use that for your pick up. Just pull the sender out remove the feul pump from it along with the hose that goes from the pump to the top of the sending unit, run your hose from the where the top of the sender hooked up to the feul pump and run it to the bottom of the feul bowl in the sender, probalby cost you less than $10
