FASS Fuel Pressures???
WAs just wondering what the common fuel pressure for a new FASS 95/150? Mine is at 13 psi and I can pull it down to 9 psi. Does that sound right? My old FASS 95/150 was 14psi and I could only pull it down to 12 psi. What gives?
Mine buries my 15# gauge at idle, at cruising speeds I have 14-13, and at WOT I can draw it down to 11.
Joe
Joe
I use an ISSPRO mechanical gauge with isolator tapped from the line feeding directly to the VP. That line is from FASS and we eliminated the stock fuel filter & housing running directly from the FASS unit to the VP. My FASS is the pn 150/95-1008 which is the 95gph pump for my '01 truck.
I'm seeing 13.5 consistant and steady at idle and down to 13 while normail drving, hwy and around town...at full throttle I can get as low as 11.5 or 12.
This ones brand new, maybe they make them that way because this thing is silent when running. I wonder if I can change the PSI output with a different spring?
Ahhhhh, thanks Bnold, I thought so. I tried to stretch this spring but it made no difference. Dan's not on here and is hard to get ahold of. How does a guy know which one to order?
i went to a hardware store and bought a box of misc spring for like $ 5 bucks and tried the ones that had just a little bit of difference and it worked i went from 13 psi at idle and 10 wot to 20 at idle and 15 wot.
I would think any FASS dealer would have access to different springs. Forget which part number mine was...
O.T
09-18-2007 12:50 PM
toupee
06-27-2007 04:19 PM
