FASS filter replacement??? NAPA FILTER?
does anyone out there have the chart for replacement filters i had it saved at one point in time but now it lost and i cant seem to find the chart online for the life of me.
NAPA Part numbers:
1274 ---- 10 Micron
1202 ---- 5 Micron (EDIT!!! I had a misprint on the part number....sorry!!!!
Filter cross part numbers....
Fleedguard:
HF6604 ---- 3 Micron
1274 ---- 10 Micron
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
Fleedguard:
Originally Posted by storx
is the
FleetGuard
FS1000
ok for water/fuel seperator its not 100 micron like the stok filter its 10 micron
FleetGuard
FS1000
Right.....you don’t want very fine micron rating on the WS.....this is on the suction side of the pump.....don’t want to induce cavitation......
so the 10 micron wont work???? at all????
also i need to figure out why the top of the pump is leaking......all the lines lead to the top of the pump
Sure...that is the FF-1010. That is what comes stock on the system.
The water seporator can be reused. Just fill with some Gas and rinse, and repeat until clean. The water seporator is 140 Micron to keep big junk from getting into the Gerotor. You dont want a super fine filter on this side since its on the suction side.
As for the leak, make sure you have Thread sealant on all pipe fittings. If you dont, it will leak. Check the weep hole as well in the motor base. How new is your unit? SN#?
Forgot to ask...where did you get the FS1000 part number?
Its the FG version of our WS. Exact same.......
That FS1000 can work. BUT you do not want a fine micron rating on your suction side of the pump. I hear there is a 2 micron filter that goes where our water separator is.......this may cause cavitation. You want to put the load on the pressure side of the pump, not the suction side.
Micron Ratings for NAPA filters
Diesel Dan,
First post. Great resource site for info.
What source did you use to determine the micron ratings for the alternative FASS filters that you suggested? I am unable to acquire these details from the online NAPA parts search, or from discussions with NAPA parts personnel. Any feedback greatly appreciated. Thanks. -RambinWreck
NAPA Part numbers:
1274 ---- 10 Micron
1203 ---- 5 Micron
NAPA Part numbers:
1274 ---- 10 Micron
1203 ---- 5 Micron
Napa filters are Wix filters. AND the part numbers are almost the same. All you have to do is add a 5 in front of the NAPA part number (5XXXX).
SO with that being said....take a trip to the Wix web site and plug in the info there.
51202
1274 -- i looked at this one...and something is not correct. I will have to check my part number on this one.....but honestly.....just run the 5 and be done with it.....
51202
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Thanks for the Wix info
Thanks for the info Diesel Dan.
Was just confused. I finally found some info on the NAPA site by using the FIL1203 part number. Drilling down gave me a 30 micron rating for that filter so I just wanted to confirm with you. Greatly appreciate the info. -RamblinWreck
Yeah.....you found that i had typed a 3 where a 2 should have been!!
![Dummy!](https://www.dieseltruckresource.com/forums/images/smilies/new1/smashfreakB.gif)
No.....add only a 5 when refering to Wix......MAN! I know we sell the 1010 WAY cheaper than that though our dealer! I need to get Rjohnson on here...he runs a Baldwin that was pretty good priced.....i just dont konw they part number....
