FASS or FASS 2
FASS or FASS 2
New to this and have question . I have an 01 and heard about the expense when the lift pump goes out do to lake of fuel pressure. I want to install somethig to remidy this. I say how expense the FASS is and wanted to know if the FASS 2 will do what I need it to. Or is there another system out there. WHERE TO BUY? I live near St Louis and seems like there is no performance diesel dealers here. Will take any or all help on this. Thanks!
01 qd cab 4X4 Straight pipe BHAF Silencer ring MIA
You can relocate the lp, replace with holly pump or fass II, or install fass system. Regardless which setup you get you should be looking at swapping out the banjo bolts and fuel lines for less restriction.
I went with a stock lp relocated to the frame and my 15 psi guage is pegged at idle and never drops past 12 psi. Do a search for vulcan relocation as an alternative option.
FASS II is the way to go. $370.00 bucks for the pump, the harness, all the fittings, 4 year unlimited mileage warranty. Thats why I got it. I got 12k on mine and its great.
Take a drive down I-44, and talk to Keith at Forest City Diesel in St. James. He sells and installs the FASS. His number is (573) 265-5595. He's a great guy who knows a thing-or-two about the Cummins.
Good Luck,
Nick
Good Luck,
Nick
BCarmicle
13
11-07-2005 05:20 PM
Buckshotmckee
05-23-2005 01:08 AM
Flatty
04-25-2005 01:49 PM
