FASS is in but?
The kit comes with every thing you need from the tank outlet to the VP44. The only thing factory left when your finished is the VP44 to tank return and the tank pick up.
Originally posted by njoverkill
I'll be running 3/8" SAE J03R9. Wonder if I should've gone with 1/2". It'd seem weird running 1/2" when the port on the vp44 is so small. But I guess if the bottleneck is RIGHT at the vp44 it doesn't matter much(?)
brandon.
Does FASS come with fuel lines or uses stock fuel lines?
I put this together for my system... No idea what kind of pressure it'll give me or HP it'll support.
This is 12mm x 1.5mm weber carb (vp44) to -6an adapter, -6 an female 90 degree -6an female, -6an male to 3/8" npt male with 1/8" npt fuel pressure gauge port
njoverkill,
Where did you get your fuel system components? Specifically the tapped -6an to 3/8npt fitting. I just ordered the "FASS II" (pump only) and need to remake a new hookup for my needle valve/FP gauge in between the filter housing and VP44.
Thanks !
I got mine at Jegs since they are local.
http://www.jegs.com/cgi-bin/ncommerc...61&cgrfnbr=509
brandon.
brandon.
BlueDually
08-28-2006 09:44 AM
8mpg
05-14-2006 12:18 PM
Buz
06-12-2005 07:39 PM
