Fass 95 or 150 GPH?
Old 06-28-2007 | 11:15 AM
WS6HUMMER's Avatar
Fass 95 or 150 GPH?
What would you guys reccomend for my 00? The only major mod I have is a TST PM3.
Old 06-28-2007 | 11:21 AM
R.T.D.H.S.P.'s Avatar
Hey just a quick question for you? In your sig you say intake duct removed. What exactly do you mean?
Old 06-28-2007 | 11:48 AM
hic316's Avatar
I have the 95, and it works great, especially if you are not going through the roof with mods. a little bit cheaper too.
Old 06-28-2007 | 03:10 PM
WS6HUMMER's Avatar
It's just the little duct that connects the air cleaner housing to the fender.
Old 06-28-2007 | 03:12 PM
WS6HUMMER's Avatar
I just wanted to make sure it would keep up with my TST PM3, what do you think?
Old 06-28-2007 | 03:13 PM
newconcorddodge's Avatar
I went with the 95 it works great and will keep up probably unless your putting on major hp mods.
Old 06-28-2007 | 03:52 PM
JStull's Avatar
I ran a 95gph pump on my '01 with smarty, comp and supermentals with no problems. I had it 3 years and I heard that the 150 gph pump required a suction tube mod. I had 1/2" plumbed in anyway but just to let you know that is what I heard.
I think the 95 is plenty for what you have. I never got below 12 psi with mine. It idled at 19 or 20 psi with a heavy spring in it.
Oh yeah and I had the pump only, not the filters so I went ahead and changed the stock plumbing from the fuel filter to the injection pump with -6 hose and fittings. It made no difference that I could notice in performance or fuel pressure. If I had to do it again, I wouldn't bother changing the lines from the filter to the injection pump. Just my $.02.
Later,
Jason
Old 07-02-2007 | 08:30 AM
WS6HUMMER's Avatar
Thanks guys, I decided to go with the 95 GPH.
Old 07-02-2007 | 10:09 AM
Diesel-Dan's Avatar
The:
150/95-1008
or
95/95-1008
or
HPFP-95-1003
....will be perfect for ya......
Ramtuff06
08-21-2007 07:21 AM
Liberatordodge
21
03-01-2007 03:45 PM
razor6
04-28-2006 11:18 PM
RowJ
23
03-23-2006 11:15 AM
Dave04600
09-06-2005 11:34 PM
Quick Reply: Fass 95 or 150 GPH?
