Fass?
Old 07-10-2007 | 10:15 PM
Jturs's Avatar
Fass?
ok i have pretty much made up my mind on some upgrades and i plan on gettin a juice w/ att. maybe some Rv 275s, and a new turbo but havnt decided on one yet. which brings me to my question should i get a FASS, big line kit, and a new feed pump. still kinda new to this stuff any suggestions or commments greatly appreciated!
Old 07-10-2007 | 10:32 PM
airplaneman00's Avatar
I hear if you get the FASS, you dont need the big line kit
Old 07-10-2007 | 10:37 PM
Jturs's Avatar
oh thanks is a FASS recommened with any fueling mods or something? dont really understand the point of it. cause i see people with pretty highly modded trucks running FASS any some not.
Old 07-10-2007 | 11:36 PM
BBA's Avatar
BBA
I have a FASS and dont really have alot of mods it helped out quite a bit to i really like it.
Old 07-10-2007 | 11:45 PM
rockjeep73's Avatar
Anything besides the stock lift pump is recomended for fueling over stock. I am running a FASS on my truck and I would highly recomend one. They have a good record of being reliable and will push all the fuel you will ever need. The FASS kit comes with all fuel lines to upgrade from the small stock ones. I would also recomend a fuel pressure gauge on all 24valves.
Old 07-11-2007 | 01:57 AM
Jturs's Avatar
alright thanks guys. does the FASS just go underneath the truck and splice into the fuel lines. sry bout the newb Q's. cause i think my truck had the in tank conversion done before i bought it.
Old 07-11-2007 | 02:01 AM
rockjeep73's Avatar
Yes, the FASS goes underneath the truck and it comes with a new larger than stock fuel line which attaches to the tank and goes all the way right into the pump.
Old 07-11-2007 | 03:04 AM
Jturs's Avatar
ok thanks for the help. so should i be looking into a 95 or 150 gph system. i plan on having good reliable towing power!
Old 07-11-2007 | 12:34 PM
Speed Shift's Avatar
Originally Posted by Jturs
ok thanks for the help. so should i be looking into a 95 or 150 gpm system. i plan on having good reliable towing power!
Its always better to have too much fuel, than not enough.
Old 07-11-2007 | 12:39 PM
WS6HUMMER's Avatar
My brand new fass only makes 9 PSI @ WOT and its brand new.
Old 07-11-2007 | 07:06 PM
afoulk's Avatar
Theres also the Airdog fuel systems. They come with 1/2 in. lines, the replacement filters are cheaper, and I think they flow somewhere between 95-110gph. However, I think FASS rescently came out with a 6year warranty on their pumps vs. 1 year on the Airdogs.
Old 07-11-2007 | 07:59 PM
Jturs's Avatar
so what GPH should i be looking into?
cause this only applies to a point right?
Old 07-11-2007 | 08:08 PM
rockjeep73's Avatar
I would go with the 95gpm. Some people with the 150 have had problems with it sucking the sump dry to the volume of fuel that it moves. Plus the 95 will be more than enough for your truck. I have a 95 on mine and my truck dynoed 700hp, and I dont have a fuel supply problem.
Old 07-11-2007 | 08:12 PM
Jturs's Avatar
thanks. is it recommended to get a new feed pump also? or should those only be replaced when they go out?
Old 07-11-2007 | 08:19 PM
rockjeep73's Avatar
The FASS is the feed pump, or lift pump. It is the electric fuel pump that feeds the injection pump. The FASS replaces the factory lift pump and lasts much longer and flows a lot more fuel.
