fan clutch
Old 07-05-2008 | 12:09 PM
rebal's Avatar
fan clutch
high perf fan clutch
does any one have a part # or good source to get one my a/c wont work at idle
because the dumb fan stops pulling (3 hayden fan clutches all bad ,napa) its for a 97 12v
Old 07-08-2008 | 02:11 AM
totalloser's Avatar
The fan clutch shouldn't affect the a/c. The pulley will still be turning. Unless you mean the A/C clutch, but those things are pretty much in or out, so maybe your a/c compressor is not keeping the pressure up? I'd try a recharge. If you have r134a, you can get a can at a parts store for 20 bucks or something, and it's super easy to do.
Or maybe there is something unique to the 12valve that I am missing. If so, please excuse my goof.
Old 07-08-2008 | 11:05 PM
badme's Avatar
The fan needs to turn to cool the condenser, it needs air. When you are driving the air is blown through it. I would use a universal electric fan if it was me.
Old 07-09-2008 | 12:03 AM
wcbcruzer's Avatar
I never really thought about the fan clutch being bad. My A/C doesn't blow that cold at idle either. I think it's normal. All our cars do it.
Old 07-09-2008 | 08:50 AM
badme's Avatar
my a/c blows cold at idle.
Old 07-09-2008 | 08:56 AM
CTD01's Avatar
Mine is the same way. I was thinkin about putting an aux electric fan.
Old 07-09-2008 | 12:35 PM
Ed ke6bnl's Avatar
Mine blows cold but not quite as cold as while running, that is a factor of the btu output is a factor of the rpm of the compressor and also the high pressure with less air movement over the cond. the pressure will increase and the evap pressure will also increase slightly. Ed
Old 07-09-2008 | 09:26 PM
rebal's Avatar
well i coughed up for a mopar fan clutch A/C is now 30* an idle for what its worth dont by NAPA (hayden) 3 bad out of the box .the mopar fan clutch pulls alot of air at idle.
FamilyDiesel
03-30-2008 06:53 AM
jrs_dodge_diesel
09-28-2007 12:38 PM
MmmDieselFumes
09-27-2007 07:44 PM
MmmDieselFumes
09-27-2007 04:04 PM
big jimmy
07-07-2006 02:33 PM
