F1 Camshafts
I'm running one in my 12v and installed one in a 3rd gen. Coupled with the 4000gsk and a B1 it makes mine pull HARD from 1300rpm to 4000rpm. It's a nice, flat torque curve that doesn't drop off. The owner of the 3rd gen is extremely pleased. It's also a nice, flat, monster torque curve that brought EGT down and moves some serious air. Cruising at interstate speeds he picked up 2mpg (hand calc'd) on the trip home.
brnadon.
brnadon.
brnadon.
brnadon.
how much do the helix cams cost? and can they be put in by a do-it-yourselfer or is it better to let a pro do it?
im thinking next yeat im gonna pull the head for o-rings and studs, so i may throw a cam in it then
Originally Posted by Ph4tty
Its pretty labor intensive. Cams are only $750 though.
i want a cam mostly for the EGT drop and sound change in the engine rather than the overall pwoer gain. i gotta see if i can find the video on dieselgarage.com that showed a 3rd gen with a heavy lope...single stack thru the hood, and every time the engine loped at idle it put out a perfect smoke ring into the air, that was a serious cam and some radical timing
Originally Posted by getblown5.9
i know the helix cams are basically like the best out there...but i see haisley, sheid, PDR, and woodruff diesel all listing a cam for the $350-450 range...how do they compare? i mean how much more power is a helix cam going to make etc?
The third gen in the video is a p-pumped 3rd gen. His idle isn't so much of a cam change as it is a injection timing change. If you want the lopey idle, you'll need to go with large amounts of timing advance.
brandon.
Brandon buddy, what have done to your pump? What cc number you at yet? I remember seeing that you have the 4K spring and a plate. Is your motor as strong as your old 24valver?
brandon.
brandon.
Those DV's will wake it up though, should put him over the 500 mark, or close to it!!
He's always trying to talk me out of my 913 pump for some reason???
Chris
ON EDIT!! I meant "mild" compared to his old truck...not that it's lacking for power or anything
