ez edge settings
Old 04-10-2009 | 11:39 AM
REDNECK-WELDING's Avatar
from what i hear more timing results in better fuel mileage, so im wondering if this has timing in the chip and if it dosent would i get better milage with say the edge juice ?
Old 04-10-2009 | 01:34 PM
Beast2B's Avatar
the ez, comp and juice all have timing built in. good luck finding out which one has how much timing, pretty tight as far as info goes!
i like the Smarty because the parameters are adjustable. just from my own experience in the last 6 weeks of commuting i get the best mileage with the Smarty on max timing and NO ez plugged in.
Old 04-10-2009 | 06:34 PM
thanks. would the comp or juice be better as that have more setting=more timing and the injection pump will be tapped?
Old 04-11-2009 | 12:13 AM
nickg's Avatar
I ran both EZ and J/A, I cant say I saw much improvement in mileage, but it might have as at the time I was only running on level 4X4 I was not using level 5 if hardly at all. I had my truck flashed with a Smarty, just so I could get the hi-idle feature.....and the side effect was a noticable improvement in mileage, 2 days after the Smarty flash I did a 1130km hot shot, the truck also idled for 4hours at 1200rpm in minus 30C weather, and I was in 4 wheel drive for at least 400kms of that trip. and it cost me 135$ in fuel (fuel at the time was around .80 cents a liter), I dont know what I got for mileage, cause it was not a typical hi-way run, even in 4WD and with excessive idling, I still got better mileage than I ever did in the past 120,000kms I've put on this truck in the past 2yrs.
just my observation but it seems as most persons report better mileage when running higher performance levels vice the "economy" level.
I believe my stock programming must have been pretty crappy, cause ever since the Smarty download, my truck gets much better mileage than it did in the past
powerstrokin03
05-05-2005 02:32 PM
03CTDCO
11-23-2004 05:23 AM
redram
03-29-2004 09:43 PM
Dodgezilla
11-12-2003 10:16 AM
cmckinney
07-16-2003 11:58 AM
