External wg question
I have been searching for external wgs lately I found a bunch on ebay like this one http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
What do I need to look for when buying a wg? Oh yeah this is for twins setup 34/40 ht3b.
Thanks
Thanks
I have seen several manifolds with a wastegate outlet welded into them. Has anyone had trouble with them cracking at the weld. I know the stock manifold doesn't weld very well. Not sure about the ATS. I just bought a Tial 38 for the twins I am building. Got it from O. Poole.
I would imagine the ATS manifold will take to welding better, but if you weld with a nickle rod, welding to the stocker should be fine. don't tell anyone, but I've had good success welding steel to cast iron with just a regular old mild steel MIG wire (only do that on my own junk though!!)
Forrest
Forrest
Is there an advantage to building a spacer or welding it to the manifold?(I would rather weld it to the manifold). I heard that a good place to dump the exhaust from the wastgate is in the hot pipe to help the big turbo spool.
ScienceOfSpeed
08-05-2009 07:37 PM
Ghost Ram
12-30-2007 01:16 PM
KatDiesel
03-11-2004 07:31 AM
