external transmission filter?
Anyone running an external transmission filter? Im interested in doing it but Im unsure of the plumbing. Id prefer to use transmission hose rather than solid lines if possible. Lots of rot on the fuel lines as it is.
Originally Posted by kawi600
Im seeing a lot of sooty clutch material in the oil that Id like to filter out. The internal one doesnt look like its picking it up
I sure don't see where adding one would hurt. As much as a good tranny costs I think an ounce of prevention would be good. Look at DieselSite.com . They have one that goes in full bypass mode if it clogs up. I have not seen anyone elses mention this advantage.
I need to limp along with my stock transmission until I can afford the cost of upgrading it. Doesnt seem like it can be done in parts, it has to all be done at once and thats a killer on the wallet =(
Man I understand. I am about to embark on the least fun part of bombing and thats going to be rebuilding my tranny. I am just going to order some parts each month, rebuild kit, VB, TC and rebuild as I can. This part will take me at least 4 - 5 months. Then I'll start having more fun with fuelin' it up .
I just plonked down the 2k deposit on the parts for a DTT rebuild, so I dont think Im going to install the filter but Ill ask my mechanic what he thinks of doing it on the rebuild.
I'm running one
Main reason for me is that I'm running amsoil full syn trans fluid ...it's good for 100,000 miles , I'm still running the stock filter , but off the return line I piped in a baldwin filter mount ...I forget the # but the filter I chose was a bt365 ...it's a 23 micron filter ...it is a little long , but the 18 mircon is smaller but dose not flow as much and I had consern with return flow .
That was main reason for the filter is so I can just change a filter out and not have to drop to get to the filter .
Other wise I would think is was a little over kill and a lot of work and money ...you should do the trans hose at the same time .
Hope this helps
Greg
Hope this helps
Greg
Hi All,
I installed a remote filter in my tranny and still use the exisiting pan filter. I installed a "spin on" filter unit and a pure one filter PH8A unit. from outlet line of the tranny to the cooler(s), before it goes into the first engine coolant/tranny fluid heat exchanger. If you start chewing up your Torque Converter disk(s) material, it could plug your cooler(s) and also contaminate the rest of the tranny, escpecially those electronic governer dodads in the 47RE and poss later?
I also installed a pressure switch inline to monitor the lock up pressure while I was at it. I'll try to post pics, someone else was asking this awhile ago and life got in the way
Dieselsite tranny filter housing w/ 90 degree bracket
Dieselsite pressure guage made for this housing
1- 3/8" ball valve( 3/8" FPT x 3/8" FPT)
2- 3/8" 90 degree brass fittings(3/8" MPT to 3/8" barb)to attach to ends of ball valve
Badwin filters- your choice on amount
7' 5/8" hose, 3' 3/8"hose---all oil resistant
2- 3/4" MPT to 5/8" barb 90 degree brass fittingsto mount on in/out of filter housing
2- 1/2" compression to 5/8" barb 90 degree brass fittings to tap into 1/2" tranny return line
2- 5/8" to 5/8" to 3/8" heater hose tees
Exhaust clamp made to fit snug around your intercooer pipe-driver's side
Zip ties
Hose clamps- if you can locate them, get the Corbin style clamps,(NAPA, ACE, TRUE VALUE) the kind you squeeze with piers to get on.Much cleaner in appearance and worm style clamps tend to get loose and cut into your hose. I have yet to see a leak with these. 8-5/8" and 4 -3/8"
When you get done with this, PM me and I'll share with you my bypass coolant filter parts and install.
Let me know if I can be of more help. Carmyne
I'm running a Magnefine inline tranny filter in my Honda Accord. It uses magnets as well as a filter element to filter crap out of the tranny fluid. And it's very easy to install. Costs about $20... You can get it at:
http://www.emergingenterprises.com/s...1Magnefine.htm
I took some cut open pics after 30K miles:
http://www.v6performance.net/forums/...ight=magnefine
I would be worried if that came out of my auto!
You have a serious problem in there!
IMO a well built and operating auto should not need more than the stock filter and regular fluid changes, and since the fluid coming out of the converter is at a fairly low pressure the extra resistance thru the extra filter could be a problem no? I know of someone that killed a tranny from plumbing on a external cooler with long lengths of tiny 3/8 hose and that slowed the oil flow to much.
