Explain why we would need these??
Old 12-23-2005 | 07:33 AM
Sea01Cummer's Avatar
I robbed it from some guy, want it back?
Steve
Old 12-23-2005 | 09:43 AM
2500CTD's Avatar
Steve
Nah i got my own!!
Got the idea from here: Disturbed If I could only get the eyes to do that in my avatar.....
Old 12-23-2005 | 12:04 PM
CTD NUT's Avatar
Originally Posted by Rare1
This picture is a good indication of just why a very high powered and high revving CTD can benefit from billet aluminum rods - just look at the sheer mass of them.....the reciprocating mass on a CTD is VERY high.....loading of the crankshaft can increase exponentially with rpm.....anything that can be done to lower the reciprocating mass can greatly help the bottom end stay together at very rpm and hp. Of course, these rods are not at all applicable to a street driven CTD but rather they are intended for those who are pushing the power and rpm limits of these engines.
Old 12-23-2005 | 01:22 PM
Don M's Avatar
DTR Advertiser
That ally rod will fail. Skip the Voo Doo stuff.
Don~
Old 12-24-2005 | 05:14 PM
Rare1's Avatar
"That ally rod will fail. Skip the Voo Doo stuff." Don M
Thanks, that's what I was thinking. Cummins says we need these monster rods in a std engine. If we are "pushing the power and rpm limits of these engines" why would you use something weaker?
"help the bottom end stay together" A 175 lb crankshaft doesn't need any help.
Old 12-24-2005 | 08:03 PM
The part i like is compared to the competition , our rods are over biult by looking at the powerjoke rods that are small to start with. Did i mention i love my truck and getting rid of the powerjoke was the best idea i have had in a very , very long time. Merry X-Mas everyone!!!!!!
Steve
Old 12-25-2005 | 12:37 AM
joefarmer's Avatar
FWIW, the Cummins B-series crank I shipped weighed ~85lbs. It wasn't that heavy, just awkward.
brnadon.
Old 12-25-2005 | 09:16 PM
A.K.APARTSMAN's Avatar
nice paper weight,,, not worth 1600 buckers
Old 12-25-2005 | 09:23 PM
Rhino's Avatar
I don't need them because I would not give that guy a dollar He is not an honest businessman.
Old 12-25-2005 | 11:34 PM
Rare1's Avatar
Originally Posted by joefarmer
FWIW, the Cummins B-series crank I shipped weighed ~85lbs...
OOPS. My source (obviously unreliable) told me it was 175 pounds. Sorry to mislead everyone and publish a false statement.
Old 12-26-2005 | 12:18 AM
Boatnik's Avatar
I think you guys are missing the point about those rods.............They would make lovely book ends and table lamps.
Old 12-26-2005 | 01:59 AM
joefarmer's Avatar
That's quite alright, for all I know my stock crank was lightened from the factory or something strange. I found another post on TDR that claimed 150lbs- I doubt that many peope have even weighed it so they just guess?
brandon.
Old 12-26-2005 | 08:21 AM
signature600's Avatar
I now know what a head and block weighs... A little rough on the back though
If anyone changed the rods in an engine, I think the new CR Cracked Cap design would be worth swapping in, and it's a factory Cummins part
Chris
Old 12-26-2005 | 09:19 AM
Mike Holmen's Avatar
The Guru
Most people buy aluminum rods for high rpm applications. Its to reduce the rotating mass. Saving amost 2lbs per rod is alot of weight. Multiply that by 6, do the centrifugal weight calculation, your probably reducing a ton of weight. Your engine would accerate faster. Mate these rods to some light weight pistons you would have a fast reving engine that would be only good for a few passes before you would have to pull the bottom end to see if the rods have stretched. I saw Piers putting together a race car with a 12v. You should have seen the size of the primary turbo, it was about twice the of the 3b turbo. If Piers is doing this I'm sure there is other fellas doing the same. You would probably have a car that could run low 9's, with little or no maintaince for an entire season. To bad you can't buy a aluminum block and head. That would make for an interesting hot rod motor for your challenger or cuda.
ktmrdr85
50
12-21-2016 12:30 AM
ARIZONACLASSIC
06-25-2010 08:36 AM
bridleman
01-22-2009 12:14 PM
sgrooms
21
04-08-2008 12:17 PM
