Exhaust manifolds: ATS vs HTT..
Old 09-01-2007 | 03:03 AM
HOHN's Avatar
OK, fellas--
Anyone have any horror stories or relevant praises for either one?
I can't really tell anything from the pics, and the designs are basically the same.
The availability of the T4 flange on the ATS is a big plus, though-- I'm consider a turbo with that kind of inlet. Any real negatives to the T4 inlet? Seems to me it might hurt spoolup a bit.... But it would bolt right to a Pro52 or a GT40 or GT42 Garrett..
I'd prefer the manifold that is the heavier of the two, if there is any weight difference...
Thanks.
Justin
Old 09-01-2007 | 07:50 AM
dieselrob's Avatar
I never seen an htt manifold, but my ats one is beefy. Its gotta be twice as thick if not more and twice as heavey if not more than the stocker.
Old 09-01-2007 | 09:00 AM
Mountaineer's Avatar
I would also like a comparison between the two. One of my concerns is with say a three piece is the possibility of them leaking Ex.Gas somewhat out the joints. I have heard of guys and recently read a post on here about some guy having that issue and that it never sealed right from the day he received it. Surely that subject was addressed in the Design and Development of the piece. Hopefully that is a rare occurrence and is not a issue.
Although you really didn't have to worry about this with the one piece Cummins used on there unless it cracked.
Again I also would also like to hear of those that could give some factual info on the ATS - HTT comparison.
Old 09-01-2007 | 09:29 AM
signature600's Avatar
I have a Joe Hellman built ATS with a t4 flange...I think it does affect spoolup a bit, but judging from my EGT's, it flows good!
If you're leaning towards a charger that has a T4 foot, go with the big foot flange ATS!
IMHO,
Chris
Old 09-01-2007 | 01:23 PM
HOHN's Avatar
IMHO,
Chris
I am and I might!
Old 09-01-2007 | 03:33 PM
JD311's Avatar
buy what everone you wont if you look at all three side buy side the BD,ATS,and HTT. geuss what all three of them are made for those companies buy BD diesel performance.I was looking at the same thing dug up some info talked to several reps from ats and bd.they are all priced about the same it all depends on the dealer.they all have the bigger inlet as an option.
Old 09-01-2007 | 04:53 PM
HOHN's Avatar
The bigger inlet is onlt advertised as an option on the ATS.
As for being made by BD, I highly doubt that. For the longest time, the ONLY manifold you could buy was made by the old ATS Turbo (since bought out by ATS diesel-- note the different ATS logos on the manifolds vs those on the turbos).
I supposed if a guy was concerned about leakage, you could just TIG a bead around the expansion joints....
Justin
Old 09-01-2007 | 05:07 PM
Tate's Avatar
Justin
Had my ATS on for two years, never any leaks from it. When I bought mine, the word was HTT were already drilled/tapped for pyro and TIP gauge, but thats not hard to fix on the ATS.
Old 09-01-2007 | 05:14 PM
HOHN's Avatar
I wouldn't pick a manifold over another based on drilled/tapped holes. I can see how others might prefer that, though...
JMO
Old 09-01-2007 | 07:41 PM
swmnkdinthervr's Avatar
My ATS is a nice looking unit, it's been on for about 12k and the paint still looks new, it's a pretty heavy casting and a good tight fit at the joints with no leaks, all we did was clean up the opening a bit...it's a good product IMHO
Old 09-02-2007 | 03:49 PM
sixb's Avatar
I like mine easy install with no leaks. If I go with bigger turbo someday will my manifold not work? I bought the standard ats manifold. What is a t4 flange?
Old 09-02-2007 | 04:05 PM
CL2000's Avatar
I have an ATS and have seen the HTT and the ATS is alot nicer and beefer.I have no problems with it leaking either. I would go for the ATS
Old 09-02-2007 | 04:42 PM
HOHN's Avatar
It depends on the turbo. If you buy a turbo that's "designed" for our engines, then it will bolt right on to the original manifold (which is a "divided T3 inlet").
But if you want to use a larger turbo that hasn't been designed for these engines, it might have a bigger "T4 divided" inlet.
The bigger manifold outlet is designed to allow you to use these "T4" inlet turbos without having to use an adapter of some kind.
Justin
Old 09-02-2007 | 05:19 PM
bob4x4's Avatar
After seeing and installing both Htt and ATS the ATS is a bit beefier in some areas,the HTT has bigger cuts machined out for the heads of the bolts(making the wall thickness less) a slight advantage maybe for ease of install.
Bob
Old 09-03-2007 | 11:26 AM
ratsun's Avatar
Justin
I have had 3 ATS manifolds now but have not tried a Htt
I would buy another ATS if I ever need another one, my biggest beef with them a few years back was they came un-assembled and it was a hassle to have to heat them up in the oven and all that crap to assemble them but my last 2 came assembled so....all is good. They have a lot of meat around the ports for gasket matching and the material they use cuts easy with a carbide cutter and a die grinder. Get a set of the MLS gaskets and you will be set for good. I found using Allen head cap screws with lock washers the mounting bolt of choice but...? Just my $.02
sledneck1
02-14-2008 11:29 AM
CTD_Neil
10-24-2007 08:39 PM
Sapps
03-28-2007 08:42 AM
koonster
27
02-16-2006 10:13 PM
Bobcat698
33
09-25-2005 10:31 PM
