Exhaust Brakes
Old 10-31-2007 | 10:08 PM
bridleman's Avatar
Exhaust Brakes
Is there any company that makes a E/B for a aftermarket turbo with a 4" down pipe?
Old 11-01-2007 | 09:18 AM
Mule Skinner's Avatar
Just going for a ride on this thread, I am also looking for 4" exhaust brake if available.
Old 11-01-2007 | 10:46 AM
dodgezilla04's Avatar
pacbrake makes inline 4" ebrakes. the brake p/n is c40120(just for the brake) the kit is something different. lary from the dtr store can get them for you.
Old 11-01-2007 | 11:53 AM
Ph4tty's Avatar
US gear makes a 4" inline brake also.
Old 11-01-2007 | 08:41 PM
dieselman2300's Avatar
I just got my Pacbrake PRXB in the mail yesterday. They have 3 different mounting kits.
One of the is for stock.
Another is for an HX35 with a 4" exhaust.
The other is for a 4" band clamp (HX40 style) with a 4" exhaust.
The PRXB are the top of the line e-brakes right now. They are air activated instead of vacuum. The PRXB kit come with everything (e-brake, air compressor, air tank, all the tubing and electronics). The only things you need for it are a mounting kit and if its a manual a manual switch.
Check them out. Its a sweet setup.
Pacbrake says you can run airbags or a train horn off of the tank and compressor also.
Also, I found that modsfortrucks.com has the best prices around. I paid $1100 shipped for everything.
Old 11-07-2007 | 01:47 PM
Harold-Pacbrake's Avatar
If you give TJ a call in our tech department (1-800-663-0096) let him know your model year truck, turbo, and exhaust pipe size, he should be able to come up with a direct mount PRXB with the correct exhaust adpt size for you
Old 11-07-2007 | 09:18 PM
Travs94Ram's Avatar
I have the 4" from the turbo and the BD exhaust break so BD will work also.
CANCERMAN
04-02-2008 03:38 PM
wildcargo
11-29-2005 05:20 AM
JImbo1
13
04-18-2003 07:44 AM
