Exhaust Brake Switch Part Numbers
Just posting this for information sake. Like many members, I wanted a shifter mounted switch for my exhaust brake, and I wanted the push-pull 2 speed rear axle style. My Cummins dealer quoted me $120 for a Cummins switch which seemed pretty steep so I've done a lot of research the past week. I've come up with some part numbers that I thought I'd pass on to help anyone else looking for the same thing. The first option is a standard 2 speed axle switch. This is really an on/on switch with 2 circuits, more than what is needed, but can be made to work just fine. There is a harness that goes with it, but not absolutely necessary. What I couldn't find is a clamp to attach it to the stick. Listed are the switch number first, then the connector number (if I could find one) by various manufacturers.
Pollak 52-261, ?
Cole Hersee 50036, 40102
Eaton 32861, 38810
Napa PP6490, EC22
The second option is a single speed axle switch, on/off, which is what I purchased. I got it through NAPA, although it is manf. by Pollak. It is ready to mount to the stick, but I have had a hell of a time finding the mating connector to go with it which is pretty much needed for this switch. Finally turned to my hometown (pop. 800) parts man, he said he can get it.
NAPA PP6491, (NAPA doesn't list the conn.)
Pollak 35-320, 52-642
First two pics (Left top and bottom) are the standard 2 speed, second two the single speed
Pollak 52-261, ?
Eaton 32861, 38810
Napa PP6490, EC22
The other option is the attached link has the bracket, switch and wiring diagrams ready for each model year truck.
http://www.dieselperformance.com/ind...duct/index/93P
True, but with our kit you would not of had and I Quote:
But I am glad that it all worked out for you in the end.
The third option is to find a 10 amp rated push/pull switch & make a bracket. That's what I did, and it's working well. I have around $15 in the whole setup, but I do a lot of fab work. I agree though that the $75 was to steep for me. BD's switch looks really nice though.
FordTrax
09-22-2016 05:54 PM
Rick 12v CTD
03-21-2009 10:36 PM
