Exhaust Brake questions
Old 07-09-2005 | 05:01 PM
  #31
Mopar1973man's Avatar
Originally posted by duner
anybody had issues with their Jacobs not disengaging right away when you hit the go pedal?
Yes! I've had this happen. It the vacuum control valve failing or sticking.
I'll tell you this much. When it does hang up and you try to go with more throttle... Give it up it will suck you down to 15 MPH... PERIOD! I ended up creeping along the highway to get to a spot to pull over to disconnect the vacuum supply hose and plug it.
I'm not sure if it would hurt anything but... You could spray some WD40 in the control valve and see if it helps...
This was all before I had gauges... I would amagine the Pyro took off like a rocket!
Old 07-10-2005 | 01:37 PM
  #32
duner's Avatar
thanks, i'll take it apart and see how it's made. should be able to figure a way to solve the problem from there.
Old 07-10-2005 | 06:08 PM
  #33
blackdiesel's Avatar
Registered
i got my switch off of a old school bus that dad had bought for the motor. So it didnt cost me a thing. ill see if i can get a few pics if you still want em.
brian
Old 07-11-2005 | 09:10 AM
  #34
Moose10's Avatar
brian
Sure if you can post some pics, that would be great.
Chepest I can find the PacBrake switch is $46.35 for a switch !!! Yeah it's cheaper than the Cummins one but still.
I don't really care for that Geno's shift **** with the switch button on the top....looks too easy to hit by accident.
Old 07-11-2005 | 04:11 PM
  #35
CSAGrey1's Avatar
I have a banks brake and an automatic tranny. I am not overly impressed. It works great with the overdrive disengaged but with it on it doesnt work all that great. This is fine when I am towing (OD off) but not real helpful anyother time. Dont get me wrong it does help abit but not as much as I would like. Maybe I need the Bigger valve springs? I have a buddy that has the maually operated PAC brake and that thing will dang near out your through the windshield. All in all if I had it to do over again I would by the PAC.
Old 07-15-2005 | 01:38 PM
  #36
HiJenks's Avatar
I checked with Rocky Mountain Cummings for a Jacobs Engine Brake....They are mighty proud of theirs!!! wanted $866.13 for it and "only $760 plus for installing.
Anybody got a cheaper deal, or maybe a different brake?
Old 07-15-2005 | 01:55 PM
  #37
mkubacak's Avatar
I have not personally compared the two, but I do know that regardless of the manufacturer, you will have more retarding horsepower at higher RPM's. That is why your's is working better in third than in fourth.
Old 09-26-2005 | 07:22 PM
  #38
George&cheryl's Avatar
My Pacbrake stopped working
When I turn the Pacbrake on I can hear the compressor running but the Pacbrake isn't engaging and I don't hear that air pressure release sound that I had. Does this brake need to be lubed or what's the problem here? Anybody?
Old 09-27-2005 | 09:49 AM
  #39
Moose10's Avatar
I got mine from Mechanicsville Dodge (1-800-559-6698) for (I think) the same price. Then your best bet is to install it yourself....or I'll install it for $500 for ya
George&Cheryl, you might possibly spray some dry teflon film or something similar on the actuator arm, or call PacBrake and tell them about the brake problem and see what they say. Also, make sure the vac line going to the brake is not leaking or dis-connected.
Old 09-27-2005 | 09:55 AM
  #40
Ok thanks, I'll start there
rcs7
09-30-2009 01:05 PM
Mopar440_6
02-11-2007 11:50 PM
coalburner400
08-01-2006 07:37 PM
2500TurboDodge
06-28-2005 10:52 PM
Quick Reply: Exhaust Brake questions
