Engine missing no codes
Old 01-21-2007 | 05:18 PM
matt02dodge's Avatar
engine misses during accelaration, 18 lbs of fp, new filters, box on leavel 1-5, no engine light, and no codes. Miss only goes away a full throttle. Seams to be worse with a load on the truck. Any suggestions on what to look for now.
Old 01-21-2007 | 08:49 PM
infidel's Avatar
Could have a bad injector. With the engine idling crack open each line at the injector one at a time. If one is bad it will be the one that doesn't cause the engine sound to change as much.
Be careful with the high pressure diesel fuel, the pressure is high enough to inject fuel right though your skin and can kill you. Wrap a rag around the injector first.
Old 01-21-2007 | 10:15 PM
good idea I never thought of it to be a injector I'll check them tommorow
Old 02-03-2007 | 08:21 PM
DriveMan's Avatar
Is this why you couldn't whoop my little gasoline powered truck?
Old 02-03-2007 | 11:31 PM
riversidediesel's Avatar
It could be your throttle sensor messin with ya, but I could be wrong.
Old 02-07-2007 | 08:22 PM
Truck still driving me nuts I checked every thing, hopfuly going to get together with some guys this weekend maby a dozen eyes are beter than 2. If it was the TPS would't it throw a code
exwrestler
02-05-2010 10:34 AM
sallyman1
08-26-2008 07:20 PM
mbenedict
07-21-2007 10:19 PM
tacohat
07-17-2006 03:27 PM
John Faughn
03-15-2006 04:06 PM
