Engine defueling with Comp ON and Mach 6s?
Old 06-19-2006, 10:05 PM
  #31
Huff nPuff's Avatar
The way I opened up my fuel system,
Was to butcher my old fuel module and plumb a 5/8in copper line into the fuel module to supply my pumps.The problem with this setup is when the tank runs below 1/2 a tank the pumps cavitate on heavy accelleration or hard braking.If I had it to to do over again I would have tried suppling a regular lift pump with Mopars new in tank pump.This way pressurizing the suction line would prevent cavitating to the regular lift pump.Diesel as well as gasoline does not behave well in a vacuum.That is why engineers have moved fuel pumps into the bottom of the tank.
Old 06-20-2006, 06:05 AM
  #32
I SPEED's Avatar
Originally Posted by CTD2001
I believe that the line from the tank to the fass pump is 1/2in, it is not stock. It is blue and it is what came with the Fass, then there is 1/2in line from the other side of the pump to the fuel filter canister, this also came with the Fass. From that point on, all the lines are stock. Does this sound right? Thanks again for the information
I'm thinking the blue line that comes with the FASS is 3/8 ID.
Old 06-20-2006, 06:36 AM
  #33
CTD2001's Avatar
thanks Doug, that was just a guess anyways, does your truck show any symptoms of what i described with your injectors and Drag comp, just curious, i know you have 200hp EDMS, Thanks
RonA
14
09-04-2007 11:09 AM
lilcummer
06-13-2007 07:07 PM
Twodiesels
12-31-2005 07:24 PM
taken5875
11-28-2005 12:19 AM
sway825
12-08-2004 10:21 PM
Quick Reply: Engine defueling with Comp ON and Mach 6s?
