Energy Suspension Motor Mount Inserts
Old 03-30-2010 | 09:27 PM
Astro's Avatar
I was flipping through a new Diesel mag while on the throne and saw that Energy Suspension was advertising their new Motor Mount Inserts for 94+ Dodge Cummins. Just curious if anyone has used them and what you have to say about them? Can you install them with the motor in place? I've used motor mount inserts on other vehicle with good results, but with a rattling Cummins, I'm concerned with excessive chassis shake. Any feedback?
Energy Suspension Part #5.1114 , lists for around $40.
Old 03-30-2010 | 10:10 PM
Escursion12V's Avatar
I installed a set in a stock set of mounts that I will be using in my conversion. They push in around the stock rubber. Fills in the open areas. The mount will have to be up out of the frame bracket to install.
Randy
Old 03-30-2010 | 10:32 PM
Astro's Avatar
Yeah, I've used these mount inserts on other vehicles I've had, just not a Cummins-powered Dodge. They always worked well in the other cars, but like I said, I'm just concerned about the shaking Cummins and how it will transmit through to the frame & cab.
Old 03-30-2010 | 10:41 PM
I would think it will stiffen it up some. I am using them because my stock rubber is cracked. Will probly be 3-4 weeks before I find out how they work.
Randy
Captain
10-30-2008 09:46 PM
Hammily
07-09-2008 10:34 AM
nvr-enuf
11-07-2007 03:09 PM
MKELLY
05-28-2005 07:35 AM
