Emjay Mount Rusting
Emjay Mount Rusting
Just wanted to warn others to check your Emjay mounting location for rust. In my case I mounted mine on the fender well since I have the Scotty II and cannot mount it in the suggested location due to that huge hole in the cowl. ;D When I removed the Emjay to get the Lock N Launch update I noticed that the fender well was starting to rust around where I drilled one of the the mounting holes.
In my case, I sanded it, put some touch-up paint on it, then put battery terminal sealer on it (all I had on hand), put grease on and through the holes, and mounted the Emjay on rubber fawcet washers so it would not make contact with the metal and cannot rub.
This may not affect those of you in dryer climates, but we've had quite a rainy season here in Virginia and I guess that was a contributing factor.
This may apply to other components you have mounted under the hood so keep it in mind.
Chris
Chris
91rangerturbo
14
02-22-2008 11:51 AM
admin
16
02-12-2003 02:50 PM
