Electric Locks vs Quad XZT+
OK! A couple of years ago this issue surfaced and I couldn't get an answer on the cause. The truck will randomly cycle the electric locks. Pull the fuse and it stops. Reinsert the fuse and it starts again. The only lasting solution (for a few years) is to unplug the XZT+ at the engine, wait 10-15 minutes, plug XZT+ back in. Cycling stops. Quad says XZT+ should not affect locks. Any thoughts? Anyone else have this issue?
Did you plug into any of the wire taps into the fuse box? I would double check those connections and make sure that they are in the right place. I would also check for a voltage drop across the power lock relay that the XZT might be affecting. Good luck
GreatTruck2001
03-04-2008 07:03 AM
GreatTruck2001
03-03-2008 06:06 PM
