egts?
egts?
I had my thermocouple installed after the turbo on the top of the downpipe last week and i was wondering how much temp im losing to know exactly what my egt is?
It will be anywhere between 0 and 500 degrees colder from what i have read. Tey will run around the same idling between pre, and post, but running hard, the pre reading could be 500* more than what you will see. I would re install it in the manifold, but if i was running it hard, i would add at least 500* to the reading.
Eric
Eric
I would move your probe to the manifold. There was a thread here about a guy that had both PRE & POST probes the differences were very wild... From 0-500*F is a good range but I still wouldn't trust it. The POST probe rises very slowly compared to PRE...
You can put a pipe plug in the old hole and drill a new one in the mainfold...
Yeah exactly what he said, take a pipe plug and put it where your thermocouple is now...and move the thermocouple to the manifold...you're a lot safer there, cause there's no guess work...
Originally Posted by cumminsdriver635
Big Blue is who ran both pre, and post. Maybe he will chime in.
Eric
Eric
It's good information...
Eric
Eric
doug
103
07-02-2003 02:27 PM
