EGT question
EGT question
My EGT sensor is located right after the turbo. I have been told that the highest temps I should see at that location either 950 or 1100 degrees. Which is the correct number?<br>Thank you!
Re:EGT question
If your stock then 300 degrees would be a good guess, and thats all it is a guess. However if your modified there has been a proven difference of upto 600 degrees between the two readings.
Re:EGT question
[quote author=Farmout link=board=7;threadid=14741;start=0#138252 date=1052962999]<br>As you see from my sig. My truck is no longer stock. How do I find out what is safe for my EGT?<br>[/quote]<br><br>Personally I would move the probe preturbo anytime your turning up the fuel. But thats just me. There is no "sure fire" way to tell you what the safe temperture is for your truck until you figure out preturbo temps.
Re:EGT question
Measuring your temp. after the turbo is about equilavent to measuring automatic temp in the oil pan. Neither tell you anything usable about how it's working.<br>Bruce
Re:EGT question
You can find some good info on installing at TST's website, at www.dodgeram.org and the dieselpage.com<br><br>hope it helps<br>wk
Re:EGT question
If you already have a post-turbo probe, I would leave it there and ADD a pre-turbo pyro. The reason for this is the pre-turbo tells you what you are pushing at the moment, but does not tell you how hot the turbo casing has gotten. The post turbo tells you how much heat is left in the turbo casing, which is the reason for the 1 - 5 minute idle cooldown recommended in the owner's manual. I miss the post turbo probe in my '03 (had it on the '99) telling me when the turbo ahs cooled enough for shutdown, and will add one for that at a later point, but I AM happy with the pre-turbo for telling me what I'm sending to the turbo for EGT's (that tells me when I need to back off the pedal or downshift). Just my .02
jmccart
03-18-2007 10:03 PM
jmccart
14
11-20-2006 06:45 PM
Sarge1124
07-14-2003 06:39 PM
