Egt Probe Placement?
Where is the most common place to mount the EGT mine was mounted in the elbow right behind the turbo, my EGT never climbs over 850-900 degrees, should I have tapped the hole in the exhaust manifold or where, becuase my readings are low, I believe?
Your Reading Will Typically Be About 300 Degrees Lower Post Turbo. Most Are Mounting In Exhaust Manifold, That is were I mounted mine. I am kind of worried to put it pre-turbo just besause if the little probe breaks off and come back through your turbo and trashes it that is big bucks.
The only reason I could ever see to have the probe mounted post-turbo was to monitor turbo cool down temps. Otherwise, pre-trubo is superior.
The back cylinders of the 24v run hotter than the front, so mount the pre-trubo probe on the rear exhaust manifold exit passage, near the flange. It is oppisite on the 12v.
There are web sites, somewhere out there, which show the proper mounting locations.
iowagn
04-15-2006 10:41 AM
wiredmojo
27
08-31-2005 12:44 PM
Chubby
09-01-2004 08:17 AM
Riverman777
11-23-2003 08:13 AM
