Egde drag hottt??
Egde drag hottt??
I want some more power for my rig but i cant decide weather i want to dish the money out for the smarty or stage 3 injectors. I already have the edge with attitude and its a 100$ to get the unlock code i just dont kno what im gettin does anyone know how much power it gives you or if its safe to use in a everyday driver?? I have an upgraded clutch but its rated at 550Hp and 1500Ft Tq
Smarty is an awfully expensive upgrade for little gain.
My vote would be injectors, or sell the Juice/Att and go with an Adrenaline which fuels as hard if not better than a Smarty/Edge stack.
I would get injectors. They will wake up your truck. If you think your truck runs good now, you will be blown away when you put in a good set of injectors.
On my old 01, I used to just run the drag comp. Then I installed some DD Mega Mentals which are rated for 150 hp gain, WOW! My truck turned into a hot rod. I know if you buy them new, they are expensive. I bought mine used with around 5000 miles on them for $655 on eBay.
I ran the stock turbo on it and when the turbo spooled up, the smoke cleaned up to a slight haze, which is perfect IMO.
So what im sayin is, for the money, I would buy injectors, hands down.
go with injectors then if you really want a smarty later on, watch the classifieds cuz there will be a lot for sale when people start getting the adrenaline.
Good point! I tried the smarty after I had injectors and it made a very nice "seat of the pants" difference. More so than the injectors by themselves IMHO.
Well I have the stock turbo and injection pump but i have the fass is that gonna be alright runnin injectors and the smarty if i choose to go with that
try injectors first. skip the smarty and look for a used turbo. then a smarty. the smarty will make your truck feel faster but it will have less total hp on a dyno if stacked with a box with added timing
Once you have all the fueling of those three you'll need a Turbo to keep it all cool! If not you may run into EGT issues. Its all give and take but most of us end up at the same place when all is said and done! I am in the market for a Turbo but its not a nessesity.
sledneck1
02-07-2007 01:57 PM
jb903
11-16-2006 10:34 AM
TheWhiteZombie
10-23-2004 05:48 AM
dodgezilla04
06-24-2004 10:27 PM
