Edm Injector size
Edm Injector size
What size edm do i need to dyno 400 to 450 at the rear wheels with a 01 ho with tst3 (not comp) with a 35/40 hybrid turbo? Trying not to go over the limitations of my new con ofe.
More Power,
I don't think you can run that much HP with a stock HX-35. If you had a quickspool B1 or Piers HX-40 and Mach 3 EDM's from Formula 1 Performance you might get there. Your ofe is only rated to 450 hp isn't it? I personally wouldn't want to the power to 450 to see if it could take it. With clutches I would stay on the safe side of power. With that kind of power the FE is what I chose on my 12v and it's solid.
I hope this helps.
Meacham Evins
I hope this helps.
Meacham Evins
Hey Don M,
Would you suggest 2.5's , or 3's for me.
Stock turbo right now, and clutch.
IF, I buy injectors (either 2.5, or 3's) I will move the plate all the way back, or put the stocker back in to keep things cool until I can get a turbo.(And an new clucth)
Tubo Plans- 35/40 Hybrid--Dodgezilla (Big Enough?)
DTR Advertiser
Mach 2's in the 12 valve are just like 370's in heat. IMO thats too much to tow with and too much for a stock turbo. I honestly dont think sliding the plate back would be ok in the EGT/towing scenerio.
Here are the 12 valve sizes:
Mach 1 power between a 215 and 370
Mach 2 370 power and heat
Mach 4 jumbo jumbo jumbo
If anything I would say a Mach 1.5 would work well for you.
Don~
Don~
Don, what is good and safe size for towing? I do have hx35 with12cm housing. Now I run 275rw with PE EZ. Thanks to Scotty II and 4 " exhaust, I dont have EGT problem. Max 1100, if I push very, very hard.
CD
CD
mtomac
32
12-20-2004 02:08 PM
