Edge product turbo charger
Lookin at stuff on the computer today, has anyone seen or yet have the new turbo that edge products makes? Just curious what people know about it or how well it works, thanks
I have not found out anything with my low boost issues yet, i have been out on the road working and have not had time to try different things, I want to real bad though, but looks like i will have to wait a little bit longer, cause i have to head out on the road monday morning again. Could it be that the truck is defueling, cause it will spike to 30psi real quick, then hold steady at about anywhere between 25 and 28psi? Thanks
Usally when i run the boost up high, i will be running along at about 55 with the overdrive off, and just a hair over 2000 rpm and i will punch, it will hit 30psi and then back off a few psi and then it will slowly climb, it is hard to watch all the gauges and keep her on the road at the same time. Can you buy boost elbow that are not from edge? If so, where and are the smaller in size then the ones from edge? Thanks again
stock03
04-22-2011 10:52 PM
