Edge Nozzels
Edge Nozzels
I was looking at gettin some edge nozzles, are those the same thing as injectors? Wasnt for sure. They have stage 1 through 5. I was wondering which ones to get? I have an 01 2500 4x4 auto with 130.000 miles original tranny, new vp and lift pump, edge juice with attitude, and 4" straight. I want some more smoke and a little power what nozzles shoud i go with or is it a bad idea? I just was not shure if the nozzles were the same as injectors probably a dumb question sorry. I would just like a little more power and some more smoke!!!!!!!!!!!
Nozzles are not the same as Injectors. Nozzles are only the tip of a injector itself. Iam going to order 100 hp but I have a 5spd I dont know what would be the best for you because of the auto tranny. But from what I have learned on here the will make you smoke.
yes thats right. Up at the search menu type in jammer nozzles and it will bring up alot of threads where people are installing and talking about nozzles thats where I got all my info. Is your pumped tapped with the juice and do you have level 6
I ran a drag comp with jammer 4s foe awile. I was failry easy on the trans and only beat on it at a roll. Dont launch at 32psi on 37 inch meats with that combo like I did...
mx684
06-30-2007 10:15 PM
mx684
05-18-2007 05:43 PM
