Edge Juice Problems
Old 12-28-2007 | 11:15 AM
Smoking S's Avatar
Edge Juice Problems
Here's the story.... Truck quit on, the injection pump went out. Put a new vp-44 on, starts up just fine, runs fine, but went to shut off and truck will not shutoff unless you tap the accelerator pedal. Unpug edge box and everything is fine. I even tried unplugging it from the the pump, but then it does the same thing, not shutting off unless tapping accelerator pedal. Took for a drive with everthing hooked up, runs like stock with no problems but but edge juice does not add no power. Anyone got any ideas? Edge box junk?
Old 12-28-2007 | 11:18 AM
JIT's Avatar
JIT
Did you turn the turbo timer off?
Old 12-28-2007 | 11:50 AM
2141pete's Avatar
Yeah the turbo timer is probly on.
Old 12-28-2007 | 12:43 PM
Smoking S's Avatar
yup that was it and for the power not being added somehow the cold weather protection got on. It all works now. Thanks guys
Old 12-28-2007 | 01:04 PM
2141pete's Avatar
I keep the cold weather protection on mine at all times. Just to be safe.
Old 12-28-2007 | 01:36 PM
newconcorddodge's Avatar
I would agree on leaving the cold engine protection on unless its not cold in the morn. Friend of mine blew the head gasket when he started getting on it with it turned all the way up and not have the truck up to right temp.
There's a reason why they put it on there.
Old 12-28-2007 | 01:43 PM
2141pete's Avatar
The only reason Mine comes off is if it has been running for a while but wont warm up all the way and I'm at the dyno or track.
MrSuzuki
08-25-2009 08:22 AM
razor6
22
01-20-2006 04:43 PM
ataboy9026
12-28-2005 06:06 PM
djcheez
10-15-2005 05:13 PM
