edge juice problem
edge juice problem
i recently removed a comp box an gauges from my dads truck and installed a juice with att. setup my question is the juice doesnt seem to be as strong as the comp and smokes alot more, i double checked all the conections and everything seems to be good.any ideas or anyboby have similar problems.
What do you have all the settings set to? max boost/ max egt/ etc? what yr truck is it? does it have an HX or HY turbo? maybe you have an intake leak somewhere, causing the black smoke.
Need more info to help ya.
try going into the set-up of the module and check to see what the perameters are set at. In each level (1-5) there is setting for throttle response. When I set them all to "most responsive" i get a pile of smoke coming out but it gets up and goes a lot better
sorry ive been out of town. the truck is a 01 and it has a turbonetics turbo on it, ive tried all the settings and checked all boost connections.yeah it is tapped,i took off the comp box and replaced it with the juice. is the comp a stronger box than the juice? i was under the impression they were pretty much the same,am i wrong.thanks
Try leaving the Backdown setting up on the monitor, that way you will know if the truck is de-fueling. as far as I know the Comp and Juice are the same performance wise.
Not that long ago I mistakenly lowered my max boost setting to zero, and I smoked like crazy and could barely keep up with a stock 3rd gen truck, I was convinced my chip was faulty, after checking thru all the menues I found my mistake. also you can call Edge for help they have excellent customer service, and if your units bad I'm certain they will make it right
MrSuzuki
08-25-2009 07:22 AM
razor6
22
01-20-2006 03:43 PM
ataboy9026
12-28-2005 05:06 PM
djcheez
10-15-2005 04:13 PM
