edge juice and low fuel light?
im going to be installing the edge juice with attitude , i have a low fuel pressure light in the truck now. is there anyways to have them both in the truck or will i have to take out the fuel light?
Short answer, yes you can use both. It's just a matter of installing the Edge fuel pressure sending unit and leaving the existing low pressure sending unit installed where it is.
That being said, you really don't need the low fuel pressure light with the Edge, it has an audible and visual low pressure alert that is user adjustable for psi.
well i dont think i can use both as the low fuel pressure light goes into the banjo fitting and theres no spot on the back to piggy back the one for the edge.
I have both, and the reason is that likely both senders will not fail at the sametime, so one will back up the other should I see low pressure, I can send you a pic if you PM me your e-mail.
I tapped into the 1/2 line about 12inches down stream from the VP,this helps with the vibration (so it wont ruin a sender) then I screwed in the needle valve (limits pulses from VP that also damage senders)then a piece of 1/4 fuel line (about 6inches long) then I installed a "T" fitting which allows me to instal both the edge sender and the low pressure sender, also had to solder a ground wire to the T fitting so that the senders would work, I installed the edge in november and I have 650hrs of use on it since Jan 09, no issues todate.
mttjma2002
07-10-2009 10:00 AM
bc3
12-01-2007 10:19 PM
razor6
22
01-20-2006 03:43 PM
ataboy9026
12-28-2005 05:06 PM
