Edge Juice with Attitude - Sensors?
Does the Edge Juice with Attitude come with all the sensors you need to monitor what they say you can? From the the instuctions is sounds like it comes with all the special fittings, but its doesn't come right out and say it comes with the sensors.....
From their website:
http://www.edgeproducts.com/product....+with+Attitude
Your Attitude monitor allows you to monitor the performance of your engines vital engine components and output values. The following parameters can be displayed on the main Attitude screen (maximum 4 at one time):
Backdown %
Voltage
EGT (exhaust gas temp)
Engine Coolant Temp
Engine Fuel Pressure (pressure of the fuel lift pump)
Fuel Temperature (measured in the VP44 injector pump)
Intake Air Temp
Engine Load % (only on later models)
Module Temperature (internal temperature of the module)
RPM
Speed MPH
Throttle %
Transmission Temp
Turbo Boost Pressure
Oil Pressure
I'm particulatly interested in the bolded items....
From their website:
Backdown %
Voltage
Engine Coolant Temp
Intake Air Temp
RPM
Speed MPH
Throttle %
Transmission Temp
Oil Pressure
Yes it comes with a special fitting to fit onto the VP44 for fuel pressure, a temp sensor for the tranny, EGT probe for the exhaust and boost is read off of your MAP sensor.
I would suggest you install a Vulcan relocation/big line kit at the same time, this will make both installs easier.
When you install the fuel pressure sensor, make sure you install a needle valve in front of it, it will keep the gauge much steadier.
I speak from experience, and have the same year truck as you do.
You will like the juice.
I was thinking about the relocation kit or a different pump, but i'm still researching that.
What do you mean by "needle valve"? I don't know what that is. got a picture or part number?
No needle valve was needed on my '01 for the Juice, I'm running a Holley Blue lift pump mounted on the frame pushing into the stock lift pump, stock lines/fittings.
5.0 Mustang Man
10-21-2008 02:50 PM
razor6
22
01-20-2006 03:43 PM
PThree
22
02-14-2005 11:11 AM
john@dps
19
12-30-2004 07:10 PM
Big Bob
12-24-2004 04:10 PM
