edge juice and airdog
I have the edge juice on my truck going to install my airdog and noticed my fuel line needs to go where the fuel pressure sender for the edge is..where do I relocate the fuel pressure sender to?????
If your in a bind there should be a port on the airdog itself. The problem with using this port is that you are only reading the pressure leaving the pump and not at the inlet to the vp. The pressure drop probably isnt much but it might be an issue.
yes and my wiring won't reach thaqt far for the sensor. does that sensor need to be grounded or is it two wire if it is two wire I think they make an inline fitting for fuel pressure
I used the inline fitting and the other day I went looking thru vulcans store for it and cant find it is it discontinued? I wanted to post a link for someone else.....could it be old age setting in
jrv15
03-23-2010 10:05 PM
kdbvulcan
20
12-06-2008 04:34 PM
razor6
22
01-20-2006 03:43 PM
