Edge Jammers
Edge Jammers
I'm seriously thinking of buying Jammer nozzles. Who has the lowest prices on Edge Jammer nozzles? I've seen stage 3's as low as $220. Anyone cheaper?
AND,
What is pop off testing? I've read disclaimers stating these need to be tested by a certified tech.
Thanks
AND,
Thanks
They need to be tested to make sure all the injectors pop off at the same pressure. If your truck has a lot of miles they will probably not all be the same and some will need shimmed. If you don't do this there's a good chance your truck will won't idle or run smoothly.
I ran jammers in one of my trucks with out testing them at all. They worked great, idled smoothly, made decent power probly not 150, but it was worth the money. I think i got mine from truckaddons.com with free shipping.
i run jammer 3's...good power, alot of smoke when i had a chip on the truck...overall i was pretty happy...however, i had mine pop tested, and they still dont have a real smooth idle. also i have to let the rpms get up pretty high and shift quick or i get a real bad surge/bucking that i didnt have before....we put the same ones in my brothers truck, and his also were tested, and have the same problem..
hyunsinsone
16
10-03-2006 01:26 PM
