edge jammer nozzles- need to be tested?
Do these nozzles need to be tested before installed in truck?? I would just think that you would receive a good product when you purchase it, but, I've heard that they need to be tested before installed from a few threads on here. So,...????????
-Ryan
-Ryan
-Ryan
-Ryan
so you need to take them to a diesel injection shop and they will install them in the injector and adjust the pop off pressure to match factory specs.
if you dont do this it could cause rough idle and/or hard starts
jake
really? 2 sets and they were both fine? Maybe I'll go ahead and get some then. Did you see any mpg change? I'm looking at jammer 4's to run w/ my EZ. Think that will be a good combo? Also, what jumper setting to put EZ on w/ 4's?? Left, middle or right??
-Ryan
-Ryan
Originally Posted by singleturnout
i ent my injectors and nozzels out and were back within the week only cost me 70.00
and blackdiesel i installed 2 sets in a row that had hard starts after install
now i pop test every set that leaves my shop
jake
xOmertAx
20
02-17-2007 09:52 PM
