Edge Jammer Nozzles
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
Originally Posted by wana12v
these are for 24v not 12v
Will these work for 12V
http://www.citydiesel.net/jammer-inj...only-p-46.html
Originally Posted by JDGnut
Those are 24V Nozzles.. different style injector.. won't work with a 12V head..
Originally Posted by cummnz4x4pwr
diesel dynamics injectors and edge nozzles are one in the same ifyou look at the part number edge has it is dd0050 for stage 5 which would be the same as the megamentals
compare at 279 for edge nozzles and 1000 for megamentals
the ultimate fueling box that dd has is the same as the edge drag comp imo
jake
jake
Oh, and the Ultimate Fueling Module is no longer around either. Edge changed all their boxes to use the DD timing curves about 2 years ago, so there is no difference now.
So if my friend was going to get a set of Jammer 4 nozzles for his 02 he'd have to take them somewhere to have them balanced and pop tested? He already pulled the other nozzles out of his stock injectors that he's going to put these in. He has RV275's in it now and wants more, that's why he's getting the 4's. The guy at gofastengineering said nothing about pop testing or balancing.
Originally Posted by Hoob
Found some edge jammer nozzles on ebay for $239 for stage 3's and $260 for stage 5's. Wondering if these are good nozzles. Will just a perf. valve body hold em? Thought these were awful cheap so just wanted to see if this deal was a little shady
But yeah i highly recommend shopping around i picked up 6 stage 5 nozzles from somewhere i researched off of google.com for around 170 dollars...
![Exclamation](https://www.dieseltruckresource.com/forums/images/icons/icon4.gif)
Originally Posted by KLockliear
Actually Jake, the old Mega Mentals were a 7-hole design. The current stuff is all Jammers. Jammers are 8-holes. Both nozzle sets and injector sets are available. Injector sets are more money, because they are complete, balanced, pop-tested injectors, not just the tip. If you buy nozzles, you will have to have them installed in your bodies, then pop-tested and balanced across the set.
You don't have to, it is defintly better, but I been runnin mine (not tested) for bout a year now. It actually idles better than stock without them tested, of course it could just be a fluke thats just my own exp with them.
Bryan
Bryan
Originally Posted by Moking 24V
Can't nobody reply to that?
You can see the other prices in the thread. Did you find them for less anywhere? I think that is less then E-bay.
Randy
