Edge J/A defuel light on
I have an 01 2500, all stock except for FASS and the Edge J/A. I have started getting the defuel light coming on and going off while driving with no driveability issues. When it comes on the power level of (4) dropes to (0) and returns back to stock.. I called Edge and they have swapped out the CS display and module under the hood with no change. Fuel pressure is a steady 14 psi. I have noticed sometimes the boost psi is set at 12-14psi on decel with apps reading at 2%. Any ideas on the problem? Maybe dirty MAP?
So nobody has ever seen this problem? Cleaned the MAP and IAT sensors with no change. Edge has no idea as well! Wondering what can cause the light to come on. Instructions says whenever a parameter is reaching it's limit....funny none are and the defuel is set to "0". I would greatly appreciate any help
sallyman1
02-22-2009 08:10 PM
hellotbone
08-27-2003 03:26 PM
