Edge EZ w/o pusher pump?
My EZ should be arriving in the mail tomorrow. I don't have gauges or a pusher pump yet. Would I be okay putting it on at the first level (or maybe second) and running around for awhile? I don't know if I can resist the temptation to install it with 65 hp sitting right there .
What do you guys think - will I be okay on the lower levels for a week or two before gauges and fuel system?
Chris
Chris
Administrator / Scooter Bum
Pusher pump would be overkill with just an EZ.
A fuel pressure gauge should be 1st on your list of "gotta-gets" though.
If you tow, a Pyro (EGT) gauge should be right up there too.
(ask DieselDude4X4 )
Re: Edge EZ w/o pusher pump?
Chris
Chris
I, too, have the ETH but noticed my EGT's were lower when I ran the EZ versus no EZ. I believe its the extra timing that allows the truck to run cooler. But I need my pyrometer checked (look at my sig).
If in fact you have the EZ, not the Comp, then you will only have "response" jumpers located on the back. Basically, more or less smoke at low boost levels. You will not have different power levels.
But you need to get a fuel pressure gauge just to see if the lift pump is working properly in the stock condition, otherwise you don't have a prayer with the EZ. Everyone else recommends pyro and boost, and I am no different...get them. Its your cheapest insurance.
Pat
Pat
I've had my EZ on for two years with no fuel delivery modifications. I ran it for 8 months without gauges. Like everyone else says, get some gauges when you can. The EZ is fairly mild, you should be fine with stock lift pump if it's still working good. Hence the need for gauges.
You do not "need" a pyro with just the EZ. OF course, gauges are always a good idea, but you won't enter into dangerous EGT with just the EZ and the boost elbow, assuming no boost leaks, etc.
A stock ETH will show you 1300° at only 21psi. The EZ will allow boost to come up to 26psi. The EZ cannot increase total fueling over stock-- just WHEN it's available. Thus, you're basically running stock fueling, only with 5psi more boost. Thus, you'll have LOWER EGT than stock.
As was said, if your LP is healthy, you're fine. I'd be more concerned with a FP gauge than I would with a Pyro if I was only running an EZ. FP is needed even on stock trucks.
Justin
Justin
I'm still running my original lift pump with the mods listed in my signature. This lift pump has over 22K miles and delivers 16+ PSIG at idle, 13-14 PSIG at 70 MPH cruise towing the heavy 5th wheel shown below, and 11-12 PSIG at WOT when towing. Obviously, with my lift pump, no pusher is needed, even with the larger DD2 injectors.
Stock, and towing a lighter 5th wheel, my truck would hit 1300 degF pre-turbo EGT @ 21 PSIG boost.
With the EZ AND THE BOOST ELBOW, I could only hit 1100 degF pre-turbo EGT @ 30 PSIG boost - this is with stock injectors and towing the same lighter 5th wheel as when the truck was stock, but also with the BHAF and 4" exhaust.
The extra boost (and resultant airflow and trapped air during combustion) is primarily responsible for the lower EGTs.
Having said all the above, I still wouldn't want to drive a BOMBed truck without at least a boost, EGT and fuel pressure gauge - add transmission temperature if it's an automatic.
Rusty
Rusty
Thanks for all the help, everyone. I didn't realize that the EZ doesn't change the max fueling - do you have to get a wire-piercing box to do that?
I'm hoping to install the EZ and a BHAF at the same time, and my rig is already straightpiped. What would you guess for dyno numbers? 250/550 maybe? Thanks!
Chris
Chris
Thanks, Shovelhead. So I'm guessing mine will be a little below those numbers then, since mine's an HO?
Also, am I correct in assuming that since the max fueling remains unchanged with the EZ, there will be no more strain on the lift pump than there is stock? Thanks again, everybody!
Chris
Chris
Big Smoky
03-23-2006 12:11 PM
midwestdually
15
12-17-2004 08:52 PM
