Edge EZ or Superchips Flashpaq?
Old 08-09-2008 | 12:38 AM
tphillips11's Avatar
Does one create more problems than the other? I have a 2002 Ram 2500 diesel and would like some extra power. Nothing to serious, maybe just 60-80hp. I know there are ALOT of different options out there but I think I have narrowed it down to these two. Any info would be great.
Thanks, Tom
Old 08-13-2008 | 04:54 AM
dsl kicks gas's Avatar
im not a big fan of either...i didnt read you sig but guagues comes first even with a simple programer/chip
between the 3 id say the superchips is the way to go.
if your only wanting around 60 hp you can get a power puck for less than 200 or pick up a used one on the fourms for around 100-125
Old 08-13-2008 | 08:34 PM
rage_blue's Avatar
i have an edge EZ. made the truck run way better. better power too, well not big power but around what i expected. I found it worked a bit better when i pluged of the waste gate tube. Don't think i would install the boost elbow, just jam a ball bearing in the watsegate tube or pinch the line off. Then i played with resistors at the map sensor, went across the two out wires at the map with 3 ohms risistor, found it gave me a bit more bottom end. and a little more black smoke. The EZ doesn't make your truck smoke much at all. had mine at the max leval and it only really put out a little smoke when you floored it at low boost levals. I would recomend the EZ for a mild power upgrade.
Old 08-13-2008 | 08:41 PM
dodge_24's Avatar
i like the banks big hoss tuner its got trans safety and it defuels before shifts
its 70 hp and 180 torque
i just finish playing with the comp box set on the ez mode and the banks fills alot more powerful
tphillips11
08-09-2008 06:40 PM
J.T
13
06-20-2006 06:01 PM
chuck gibson
04-25-2006 01:02 AM
MonroeDiesel
03-30-2006 04:00 PM
Quick Reply: Edge EZ or Superchips Flashpaq?
