Edge EZ question
Edge EZ question
When you purchase one of these they give you a replacement boost elbow with a metered hole in it but they say that it will work just as good with or without it what is the purpose of it then, because I would think that if you are able to build more boost without the wastegate opening than that turns into more power right?? Mike
Re:Edge EZ question
I dont know how the '04's are but I know that some year auto's (with the HY35) couldnt use the boost elbow. They had to use the turnbuckle or Turbo Master. But if it can be installed on yours then definatly install it. The extra boost will result in lower EGT's and yes the truck will run better. Edge said the same thing to me but it ran way better with the elbow.
rockjeep73
03-25-2005 04:34 AM
Hoss
13
06-18-2004 07:14 PM
powerwagon440
01-20-2003 09:50 PM
