Edge EZ and Boost Fooler
Boost fooling doesn't matter if you have an auto or manual. The only difference is the method of disabling the wastegate. On the HY turbos, you'll need a j-hook or something to plug the line. On the HX turbos, you can use a boost elbow to restrict flow to the wastegate.
yep, If you disable the wastegate without a boost fooler, The computer will just defuel and you wont see anymore power.
If you add a boost fooler without disableing the wastegate, then you also wont see anymore power.
These mods go hand in hand.
If you add the Edge without disableing the wastegate, you will see SOME increase in power. If you add the Edge and disable the wastegate, you will see MORE power.
Killdmycobra
11-12-2010 05:15 PM
bige124
10-08-2009 09:06 AM
SS1156
11-02-2008 10:25 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
GTSDave
07-08-2005 09:06 AM
