Edge EZ, AFE Megacannon, 4" Exhaust ???
Hi all, I just got an Edge EZ, before that I got a 4" Turbo-back exhaust system, and before that an AFE Mega cannon. I really haven't had a noticeable increase in power from any of them. From what I read about the EZ it was like "WOW", but I really didnt see it. I am not pulling anything. Anybody else have these things and "really" noticed it?<br><br>I do like the turbo sound that the AFE lets thru and the 4" Exhaust sounds pretty tuff. But I was really expecting something drastic from this EZ.<br><br>Do I need to be pulling a heavy trailer to see any improvements?<br><br>Let me know guys, thanks in advance.<br><br>Fafa
Re:Edge EZ, AFE Megacannon, 4" Exhaust ???
You might be expecting too much. Drive it for a few more weeks, then take the EZ off. Then let us know if you see a difference.<br>You might want to check the jumper setting as well. Usually comes at 3, but may be at 1 or 2. I didn't notice how many miles on your truck, but if it has been unloaded most or all of the time, pull a max load for 500 miles or so and let the engine work.<br><br>Mike
I thought mine was a pretty good improvement. Have you checked you fuel pressure lately? Low pressure will lower power levels. <br>
I felt a big improvment in my 2001 auto. when I put the EZ on. The main reason I got the EZ was for towing. I was geting ready to change from a 3:55 to a 4:10 rear-end to pull my travel trailer better. I decided to try the EZ first, it made enough diference that I did not change the gears. Mine feels like a hot rod and has surprised a lot of people with the power and how fast it is leaving stop lights.<br><br>Bill
First check the jumper setting. <br><br>If it is set correctly then remove the EZ and then I bet you will notice the difference.
Check your Fuel Pressure, & also I noticed I lost a bunch of power by putting a qt. too much of oil in the engine, got rid of it & it runs super again.<br><br>DRecu!
Ludwig,09,6.7
07-02-2011 01:06 PM
PEAKSTRYDE
10-11-2007 04:20 PM
MonroeDiesel
05-10-2003 09:04 AM
Cumminsdieselboy
57
03-10-2003 12:28 AM
