Edge Ez adjustment
Old 11-16-2004 | 01:28 PM
Brohlfs's Avatar
Edge Ez adjustment
Several have commented on adjusting the Edge EZ to levels of 4,5, and 6. How do you do this and how does it affect smoke levels. I understand the moving of jumpers but which one goes to which to make this happen. This is on 98.5 5 speed. Thank you in advance.
98. 5, 24 valve 5 speed, Edge Ez, boost elbow, 4" exhaust, fuel, EGT, Boost guages.
Old 11-16-2004 | 01:35 PM
RustyJC's Avatar
Re: Edge Ez adjustment
I believe this applies to the EZ sold for the HPCR (3rd generation) trucks.
Rusty
Old 11-16-2004 | 01:43 PM
HOHN's Avatar
Yeah, that's my impression too....
BigBlue's Avatar
You can also adjust the EZ's for the 2nd gens. Do a search and you should come up with something.
Old 11-16-2004 | 01:52 PM
RowJ's Avatar
Setting #1 = 33% of additional fueling @ 0 psi…….100% @ 20 psi
Setting #2 = 50% of additional fueling @ 0 psi…….100% @ 15 psi
Setting #3 = 67% of additional fueling @ 0 psi…….100% @ 10 psi
Setting #1 is far left, I believe.
2003 went to 4 settings, including an off position
2004.5 went back to 3 settings
#4,5&6 - ????
RJ
Old 11-16-2004 | 01:53 PM
Brohlfs's Avatar
That is what I've tried, and I can't seem to find any how to, just that it's been done. I've been looking at 2nd generation so hopefully someone has done this and can tell me how to. Thanks
Old 11-16-2004 | 02:01 PM
BIGBADBOB's Avatar
You have to open it up to see the jumpers inside, there is three positions for it. I think its a small allen head to get into it. Not sure as have not been in there for a year and leave mine on level 3.
Old 11-16-2004 | 02:05 PM
RustyJC's Avatar
Yep - 3 positions, and the instructions are in the book. Level 3 (max) is with the jumper on the far right as viewed with the label up. Level 2 is middle, and Level 1 is far left. This isn't the 6-position adjustment the original poster referred to, though.
Rusty
Old 11-16-2004 | 03:02 PM
BigBlue's Avatar
The 3rd gens are supposed to have a secret 6th level. Don't know much else about it.
Old 11-16-2004 | 03:17 PM
RustyJC's Avatar
Yes, but the original poster has a 2nd gen.
Rusty
Old 11-17-2004 | 12:46 PM
HOHN's Avatar
This is what it looks like inside a 2nd gen EZ. This is the tamest setting, which I use because I have injectors.
Justin
Old 11-17-2004 | 09:30 PM
torquedcummins's Avatar
thats odd i was always told the the edge ez was not adjustable. How much difference is felt from the first setting to the third? I have one on order so i should be getting it within the week.
Old 11-18-2004 | 08:44 AM
RowJ's Avatar
J Young
Twice the added fuel at 0 boost is a noticable difference! Lots more smoke too. It takes about 60 sec to change settings...play with it and see which you like.
RJ
Old 11-18-2004 | 09:35 AM
Mike D's Avatar
I wonder if using a telephone line or cat. line to connect to all the jumper to a 3 position switch for inside cab adjustment would work? Maybe even a four position switch to have the circuit totally open to turn the box off.
Anyone with a electronics background?
Old 11-18-2004 | 10:11 AM
RustyJC's Avatar
Remember, the EZ is tied into the CANbus and the MAP sensor. I don't know if I'd want to try changing settings "on the fly" or not. Unlike the Comp, I doubt that the EZ was designed to do that.
You're right, though - a 3 position switch and 6-conductor cable would be easy enough to rig up. In fact, you may only need a 4-conductor cable since (IIRC) all the lower pins are common. No jumper (again, IIRC) is equivalent to position #3 (max), so there's nothing to be gained there.
Rusty
