edge ez
Old 11-24-2002 | 09:57 AM
ox's Avatar
ox
edge ez
dose the edge ez make a lot of black smoke because i don't want black smoke when i get a box so if yall know wich ones that make black smoke please tell me them<br>
Old 11-24-2002 | 10:11 AM
chuck3's Avatar
Re:edge ez
On power level 3 if you floor it from a stop you will get some smoke untill the turbo spools up. What year truck? If its 01 or newer is less smoke due to smaller turbo.
Old 11-24-2002 | 12:33 PM
scottrod's Avatar
Re:edge ez
level 3 is the 3rd jumper setting inside the EZ box. They come from the factory on this setting. If you add bigger injectors, you might want to change the setting to 1 or 2 in order to reduce the amount of low rpm fueling it will provide to reduce smoke until your boost picks up.
Old 11-24-2002 | 02:51 PM
chuck3's Avatar
Re:edge ez
No Ricki, but mine is an Auto trans, which is different than a stick shift due to the low turbo speed at take off. He did not say what he had did he??? <br> So I guess it depends on if its a stick or auto on amount of smoke.<br>
Old 11-24-2002 | 09:13 PM
JR2's Avatar
JR2
Re:edge ez
An EZ will add a tiny bit of smoke to an otherwise stock truck. You can move the jumper under the back cover to position 1 and all the smoke will go away (at least till you add injectors ;D).<br><br>Moving the jumper delays the addition of the small amount of extra fuel the EZ adds. Position 1 adds the fuel at 15 psi, position 2 at 10 psi and 1 at 5 psi. (those are the #'s I remember, they could be off a little since its been so long since I read about it).
Old 11-24-2002 | 10:05 PM
PapaSmurf's Avatar
Re:edge ez
Hello<br> We have a 99 3500 auto that recently had a Edge Ez added to it. There is very little smoke out the stock pipe. This box will wake up the monster uder your hood. Low Hp gains but BIG TORQ gains. ;D ;D ;D<br><br>we also have a 01 6speed with an EZ box and DDIIs and I can smoke you pretty good if I want to. With my stock truck 8)I am putting out 326 Hp and 799 Torq.<br>Hope this helps<br>See Ya<br>Chris
jwhip
28
05-29-2005 12:32 PM
rockjeep73
03-25-2005 04:34 AM
Hoss
13
06-18-2004 07:14 PM
powerwagon440
01-20-2003 09:50 PM
