Edge EZ?
Old 03-27-2007 | 01:17 PM
CARR's Avatar
Edge EZ?
Will unpluging the map sensor on the ez work like unpluging the comp?
Old 03-27-2007 | 01:18 PM
pmtg's Avatar
yes it will
Old 03-27-2007 | 04:12 PM
CARR's Avatar
so i can expect more power on low end if i unplug the map?
Old 03-27-2007 | 04:58 PM
jlebrun's Avatar
and smoke !!!
Old 03-27-2007 | 05:03 PM
pmtg's Avatar
give it a shot...it should feel a little snappier.
Old 03-27-2007 | 05:51 PM
CARR's Avatar
I am going to try soon as i get of work!!!
Old 03-27-2007 | 10:41 PM
TNutcher's Avatar
i wired it up on mine so that its on a sort of high/low beam switch on the floor so when i want it to roll I stomp the left foot first then the right haha! another little tap and it doesnt smoke any more! tada! haha but it'll leave a great cloud
TNutcher
Old 03-28-2007 | 02:31 PM
CARR's Avatar
Well i tried it out and it didnt work! The truck ran like stock.
Old 03-28-2007 | 02:36 PM
pmtg's Avatar
sure it was the MAP and not the data link?
Old 03-28-2007 | 02:47 PM
CARR's Avatar
Im pretty sure. It is the rectangular plug near the top driver side of the motor. Am i doing this correctly?
Old 03-28-2007 | 03:07 PM
pmtg's Avatar
item #8...
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
(in the diagram its just to the right of the top of the fuel filter)
Old 03-28-2007 | 03:18 PM
CARR's Avatar
Yeah thats the one. It returned my truck back to stock when unpluged.
Old 03-28-2007 | 04:06 PM
pmtg's Avatar
did you unplug the sensor itself or the plug coming from the ECM? you only want to unplug the sensor, keep the EZ plugged to the ECM.
Old 03-28-2007 | 04:09 PM
CARR's Avatar
I dont really uderstand you have any pics?
Old 03-28-2007 | 05:24 PM
pmtg's Avatar
on a stock truck you have a plug coming from the ECM that plugs to the MAP sensor. the EZ splices into that, one part connects to the ECM plug and the other part connects to the MAP sensor. you only want to unplug the EZ from the MAP sensor.
sorry no pics but does that explain it better?
